Forums >> Revit Structure >> Technical Support >> Visibility On/Off
Wed, Jul 25, 2012 at 2:28:44 PM | Visibility On/Off
Tinman867
Tinman867 Avatar
I am working on a parametric roof opening frame and have everything but this working.  I am trying to set an On/Off Visibility Parameter for a center cope, if the roof opening frame spans more than 2 joist openings.  Can the On/Off Visibility Parameter be used with a void sweep?
Fri, Jul 27, 2012 at 2:42:47 PM | Visibility On/Off
robinballew
robinballew Avatar
3 Stars: 4 Votes
I don't think so. What you can do it make the Void change shape based on an On/Off setting. So for example if the setting is on the Void is 3' and if the setting is off it is 2' where the 2' wouldn't cut the object.
BallewDesigns.com
Fri, Jul 27, 2012 at 4:12:34 PM | Visibility On/Off
Tinman867
Tinman867 Avatar
Thank you very much.  That is what I ended up doing to get it to work.  I figured it had something to do with the void aspect of the shape.
Visibility Problem - please help!!!
Fri, Jan 11, 2008 at 10:20:02 AM
imported DWG visibility
Fri, Apr 13, 2007 at 12:26:22 AM
VISIBILITY
Mon, Aug 7, 2006 at 5:36:38 PM
Symbolic Element Visibility
Tue, Feb 4, 2020 at 6:42:28 AM
Controlling window visibility
Tue, May 12, 2009 at 12:49:39 AM
Page generation time: 0.1658
