Forums >> Revit Building >> Technical Support >> swept blend - what am i missing???
Wed, Jul 25, 2012 at 2:09:42 PM | swept blend - what am i missing???
dontpostmyname
revit 2012
swept blend, i have the two shapes i want to blend, i've drawn the path... what am i missing? i select path, select one shape, select second shape, i get this~~~~~~~~~~~~~~~~~~~~
shouldn't the two shapes connect? like in every other 3d modeling program?
Edited on: Wed, Jul 25, 2012 at 2:20:44 PM
Wed, Jul 25, 2012 at 4:49:01 PM | swept blend - what am i missing???
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
yes they will connect. follow the instructions in your help exactly. The attached is a sweep blend method for doing streets, but it is the same for different profiles and they will connect up and you in some cases will be asked to connect certain features as the shape can roll or twist one way or the other.
Swept Blend
Fri, Nov 28, 2008 at 4:39:26 PM
Please help me with swept blend!!
Mon, Jul 28, 2014 at 3:31:14 PM
cannot rotate the reference plane of a swept blend
Tue, Feb 23, 2010 at 6:22:35 AM
swept blend with more than 2 profiles
Sun, Nov 18, 2012 at 5:21:23 PM
Swept Blend for Basin
Tue, Oct 31, 2017 at 3:38:16 AM
Page generation time: 3.8250
