Forums >> Revit Building >> Technical Support >> DEMOLITION - PARTIAL DEMO OF ROOF AND WALL
Fri, Jan 6, 2006 at 9:59:00 AM | DEMOLITION - PARTIAL DEMO OF ROOF AND WALL
scathendo
doing an addition to an exisitng residence and need to demolish part of a roof and wall. any ideas?
Fri, Jan 6, 2006 at 1:42:27 PM | RE: DEMOLITION - PARTIAL DEMO OF ROOF AND WALL
quiller
quiller Avatar
2.5 Stars: 3 Votes
You can split a wall in two direction, vertical and horz. That will take care of the walls. On the roof...I would create the room in two pieces and phase demo the piece you don't want. Not sure if you can split roofs, but give it a shot.
Fri, Jan 6, 2006 at 3:57:40 PM | RE: DEMOLITION - PARTIAL DEMO OF ROOF AND WALL
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
The wall would need to be broken up in the existing phase so it can be demolished in part in the current phase. This has always annoyed me you really should be able to demolish part of an element without have to create as two separate ones. HTH
Thu, Jul 12, 2007 at 3:04:59 PM | DEMOLITION - PARTIAL DEMO OF ROOF AND WALL
MrBob
3 Stars: 2 Votes
I have an existing cmu wall with brick veneer.  Is it possible to show just the brick veneer being demolished and the cmu to stay?  Using version 9.1.
Calculate Demolition
Fri, May 8, 2015 at 3:56:11 PM
existing, demo and new roof
Wed, May 28, 2008 at 8:21:30 AM
Partial Hip Roof
Tue, Jun 26, 2007 at 3:22:10 PM
Edit Demolition Profile Tool
Wed, Mar 1, 2006 at 4:43:33 PM
show demolition in the new construction plan
Wed, Oct 1, 2008 at 11:41:23 AM
Page generation time: 0.6949
