Forums >> Revit Building >> Technical Support >> Nesting windows - sill height of nested window reporting incorrectly
Wed, Jul 25, 2012 at 10:36:55 AM | Nesting windows - sill height of nested window reporting incorrectly
abugintheground
Hi,
I have created a series of window families with nested sub-windows, in order to create runs of windows and be able to easily schedule the structural opening of the run.  Everything is, at last, working as it should, apart from that now I'm looking at the schedule and the sill heights of all the nested sub-components are completely wrong.
Any thoughts?  I've attached a screenshot of the offending schedule, along with the families in question.
Wed, Jul 25, 2012 at 10:38:12 AM | Nesting windows - sill height of nested window reporting incorrectly
abugintheground
(I'm using Revit Architecture 2012 on Windows 7)
Tue, Apr 25, 2017 at 1:21:09 AM | Nesting windows - sill height of nested window reporting incorrectly
aninharomano
Hi! I am having the same problem, did you find out why this is happening? Any solutions?
Tue, Apr 25, 2017 at 9:48:21 AM | Nesting windows - sill height of nested window reporting incorrectly
I don't believe the nested windows will report this.  If these are really seperate windows, then this is a case where grouping would be a better solution.  If they are mulled togeter windows then they might be treated as one instance.
Nesting windows - schedule info
Wed, Jul 25, 2012 at 10:12:37 AM
Actual Window Head height
Thu, Jun 7, 2007 at 5:44:29 PM
Setting Window Head Height
Fri, Feb 24, 2017 at 12:16:49 AM
14
Windows Default Sill Height
Fri, Aug 26, 2011 at 12:51:41 PM
Sill and head height of windows - in the dimension I can only show the actual
Sun, Aug 18, 2024 at 1:01:15 AM
Page generation time: 1.6710
