14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> 'unable to copy elements from file' error in inserting a saved view
6 Posts No Rating |
I made saved views from autocad details that are fully exploded and are all 2d elements. The file saves fine and i can open it. But i can't insert the view into my projects in Revit 2011. Are there compatibilty issues with Cad hatch regions or too many lines? can't find anything on-line...please help!
What do you mean "...I made saved views from autocad details..." ? if the deatils ar part of a larger file, you should wblock them out with a new origin point - somewhere close to your linework.
Don't explode CAD hatch patterns because that will result in a great number of lines. Instead, clead up the CAD import in a scrap Revit project changing your linework to your standards and the hatches too.
6 Posts No Rating |
Yes i cleaned up the Cad file in a Revit Drafting view, then 'saved the new file' so i can insert it into multiple projects. the hatch patterns are not exploded. seems to be clean. Perhaps the linetypes from CAD are not allowing it to import?
No - linetypes are never an issue.
Whoa.... you said "...I made saved views from autocad details..." - I was assuming you meant CAD imports and now you clarify that you have already done that in a drafting view.... I now see what you are doing....
You don't need, nor should you, save these details in separate files. They can, should, all be in one file - just separate views. We organize these 2D details in projects that are named for their type like a door and windows detail file. Then you use the insert tab / insert from file / insert views from file ... and pick your holding file then the selected views. << For now just use this process with your single detail projects.
Error when inserting drafting view from file "Unable to copy elements from file" |
Thu, Apr 1, 2010 at 5:06:39 PM
Revit 2016/2015 revit save to new file unable to copy elements from file |
Thu, May 5, 2016 at 2:20:37 PM
Unable to open Revit Model .Error -This family instance has too many edges. |
Mon, Oct 6, 2014 at 6:02:41 AM
'Ungroup' causing fatal error in Revit Architecture 2011 [ 1 2 ] |
Tue, Aug 24, 2010 at 4:03:21 PM
15
Can't open a Revit file. Never saw this error message before! |
Thu, Aug 7, 2008 at 4:57:55 PM
