9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> arched opening for overhead garage door
7 Posts No Rating |
I'm trying to create an arched opening for an overhead garage door. Revit won't let me modify the opening of my existing family so in the model I tried adding a short piece of wall with an arch, but when I join that wall to the existing wall with the door, the short wall disappears. I tried creating a component arch and joining it to the existing wall, but the line of the garage door shows through. Any ideas how to get rid of this line?
edit: when I tried adding the short piece of wall, the rendering was ok but the elevation showed the line of the door thru the wall
Post edited on 2004-05-13 13:06:32
admin
Why won't Revit let you modify the opening? It should let you edit the sketch in elevation view.
Hiroshi Jacobs
The Catholic University of America |
7 Posts No Rating |
I should be able to edit the opening in elevation view but the error message I get is "sketch is no longer parallel to it's defining plane"
admin
hmmm.... send me the file - hiroshij@oculusinc.com
Hiroshi Jacobs
Sounds like the head of the door is defined by a reference plane and is locked to it. Be sure that the opening (cut) and the door head is not linked to a refence plane. I assume you only want the opening arched, and not the door head, or both?
7 Posts No Rating |
I think that's why it's not working, but I have not had time to play around with it, and yes, I just need the opening arched.
Windows in a Garage Door (Help!) |
Tue, Jun 27, 2006 at 10:49:13 AM
see through door opening to door beyond |
Mon, Nov 2, 2009 at 1:46:12 PM
help with arched opening |
Mon, Dec 8, 2008 at 6:41:45 AM
Demolishing an existing door, putting an opening in its place.... |
Tue, Dec 6, 2005 at 5:04:38 PM
Arched Opening Problems |
Tue, Jan 18, 2005 at 5:06:11 PM
