Forums >> Community >> The Studio >> My pc was slow down while working w/ Revit
Thu, Sep 11, 2003 at 11:48:56 AM | My pc was slow down while working w/ Revit
Tanapong
my pc was slow down while working w/ revit: The specification of my pc CPU P4 2.4 Gb. DDR Ram 512 Mb. Display AGP 32 Mb. does anyone has experient about this topic.? your comment would be appreciated.
Thu, Sep 11, 2003 at 5:35:43 PM | RE: My pc was slow down while working w/ Revit
Admin
admin
Admin Avatar
3 Stars: 4 Votes
What opperating system are you using? What else is running in the background when you have Revit open? Just a guess, but it can't help, you might try going to www.downloads.com and searching for "free ram" or "memory optimization" You can download some free tools that will correct some "memory leak" problems.
Pierced Media, LC
Sun, Sep 14, 2003 at 2:10:50 AM | RE: My pc was slow down while working w/ Revit
Tanapong
Thanks for reply. OS windows NT 4.0 srvpack 6.0 I did not open any application while working w/ revit. I modifield project that take about 5.2 Mb. which is contain component inside such as office furniture and other component for interior office design. Regards , Tanapong S.
Tue, Sep 27, 2005 at 4:16:28 PM | RE: My pc was slow down while working w/ Revit
lmccary
We've found that a gig of ram is minimum for running Revit at our firm. Personally I would recommend more if you can get your hands on it.
Tue, Sep 27, 2005 at 4:41:53 PM | RE: My pc was slow down while working w/ Revit
TomDorner
4.5 Stars: 25 Votes
Yes, the more RAM the better. I have 1GB here at work, but the next PC purchase for either work or home will have 2GB minimum. Tom
Thu, Sep 29, 2005 at 12:09:27 AM | RE: My pc was slow down while working w/ Revit
meelio
2 Stars: 3 Votes
Certainly, the more RAM the better - but I can work very effeciently on smaller projects with only 256Mb. So memory optimization may be in order. Also, check how many windows you have open in a project - try keeping it around 4-5. Normally you shouldn't need any more.
Fri, Oct 14, 2005 at 4:54:29 AM | RE:
Boarch
Tom
We have baught 3 new computers for Revit. They are equipted with 2GB RAM, Nvidia Quadro FX1400 graphic card, 3Ghz dual processor. We are a arcitectual offic, and are working with big projects. Even with that equipment surtain comands are working slow, but much better than before.
Post edited on 2005-10-14 04:55:03
Mon, Oct 17, 2005 at 3:11:17 AM | RE: My pc was slow down while working w/ Revit
eldados
eldados Avatar
4.5 Stars: 8 Votes
I would also recomend to upgrade your video card... 32meg does not cut it anymore Sad is there any reason you are runing NT? and yes, 2gig of ram is minimum! it's so cheap today there is no reason not to have it Smile
Integrator
KarelCAD
WHY THE A.REVIT BUILDING GOES SOOO SLOW?
Fri, May 4, 2007 at 2:43:19 AM
slow model...help!
Fri, Feb 17, 2012 at 8:09:29 AM
Revit 2013 slow performance in citrix
Wed, Nov 5, 2014 at 11:03:13 AM
revit running slow
Mon, Feb 15, 2010 at 2:40:52 AM
Revit running slow on my computer
Mon, Jan 25, 2010 at 6:42:55 PM
Page generation time: 1.6857
