28 Users Online (26 Members):
Forums >> General Discussion >> Revit Project Management >> revit terrain and roads
Hello;
I've modeled a terrain in Revit. The terrain should have existing roads on it and I am also required to do the roads in 3D. I'm not allowed to use sub-regions or that kind of projections on my terrain. If I take a section from some place on the terrain I have to see the roads as object being cut as layered objects.
Can any one suggest me a modeling strategy?
As far as I can think of here is what I'm planning to do: Using sloped pads between certain spot elevations of the road and dividing the road as much as possible into little pieces. but I also have to do the same process for pavements. And I don't know what kind of joining problems I will have at the end.
Beyond that I don't want to pay some extension called siteworks for revit, because that thing had to be made first by autodesk.
Thanks in advance.
I don't understand why you need to see layered objects in sections when this can easily be added as detail work. We never model sloping/curved roads. If you must do this then you should get the civil site works add on. Otherwise, chack out this thread and pay attention to mbsteve's post.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=27738
Attached is a method to accomplish this there is also a software add on available which does this rather easily or at least it appears to, SiteWork by EaglePoint.
Also check this thread. I started making an adaptive component road that has a very smooth top surface. it won't help you model intersections, but it looks great as single long road segments.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=27733
Great. Thanks all for replying so quick.
WWHub: I agree with you about detail work, but I am a worker not the boss They want it this way.
I have read this document before, this might work but it is not so much practical.
And the oscar goes to itsmyalterego, I liked your solution. So close to eaglepoint siteworks.
How to create roads on terrain? |
Thu, Sep 27, 2018 at 11:30:56 AM
Roads in a slope |
Fri, Jan 13, 2012 at 1:47:52 PM
Where are the roads? |
Thu, Jul 17, 2008 at 2:13:40 PM
Roads |
Mon, Apr 3, 2006 at 10:21:48 AM
How to make Roads in site? |
Mon, May 31, 2010 at 4:29:42 AM
