Forums >> Revit Building >> Technical Support >> creating own wall family
Fri, Jul 20, 2012 at 1:00:17 AM | creating own wall family
dragonfly76
Hi, I've been learning Revit at Uni, I'm in my second year now....  I'm trying to create a wall to use in my current project.  So I've opened a new family file and used the generic wall template.  I've created an extrusion that looks like a stratco product.  It looks fantastic in the family file, but I can't seem to find it once I import the file into my project....  anyone know what I'm doing wrong??
I'm using version 2013.  Any help would be appreciated.
Thanks in advance.  Heidi
Fri, Jul 20, 2012 at 1:26:23 AM | creating own wall family
dragonfly76
Ok, so I've worked out the the family I created is used as a componant.  I've added it in pannels to my walls, but I can't make it connect to the roof like the wall is, help anyone??
can I make this componant so it will attact to the roof?  Or is there any way to create a new wall family that has this componant as a layer of the wall, so that it reacts the same as a normal wall??
Getting a bit frustrated!!
Thanks heaps
Fri, Jul 20, 2012 at 6:53:50 AM | creating own wall family
4 Stars: 205 Votes
Walls are "System families", you don't have any "template" to create walls, what you should do is in your project duplicate one of them then change the wall parameters like you want.
Fri, Jul 20, 2012 at 4:32:58 PM | creating own wall family
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Include a picture of the wall you want--it sounds to me like you could edit an existing wall type to be what you want.
Sun, Jul 22, 2012 at 5:55:55 AM | creating own wall family
dragonfly76
Just want something that looks like a steel sheet type product....  attached is the file I made of the stratco maxiclad product that I was trying to make.  It is the componant part I created.  I have successfully attached it to the wall as a part, but am not happy with the fact that I can't extend it, just have to place then cut as required, very time consuming, and can't make it extend to the top of the wall.
just want to make the wall look like it's got a similar product on it.   My teacher just says to find a finish that I like, but I can't seem to find anything that looks like what I want.
Thanks
Sun, Jul 22, 2012 at 8:41:39 AM | creating own wall family
Your teacher is right.  Use a material finish rather than modeling profiles.  Google "color clad", you will find some materials on their site.
Mon, Jul 23, 2012 at 11:20:17 PM | creating own wall family
dragonfly76
Thanks, been trying to get the materials finish I want and just can't find it....  working with 2013 is a bit tricky as I only just got it and learn't on 2011, things are just in different places.  I can do a checker plate finish, and a few other ones, but there is nothing that even vaguely resembles colourbond or any other type of metal cladding.
I'll have a look on the site you suggested, thanks heaps.
Mon, Jul 23, 2012 at 11:54:08 PM | creating own wall family
dragonfly76
to: wwhub
I can't find anything to do with revit when I do a search for "color clad" can you give me a site address please?
Tue, Jul 24, 2012 at 1:42:41 AM | creating own wall family
doodle1711
Try SteelSelect.com for Colorbond Textures & Renders.
Look at the bottom left corner for the Link to Revit files.
Tue, Jul 24, 2012 at 7:08:19 AM | creating own wall family
doodle,
Thanks for picking this up.  I was at home when I posted and I remembered color cland instead of colorbond.  But steel select was where I wanted to point them to.
Wall Hosted Family on Curved Wall
Mon, Jan 28, 2013 at 3:12:42 PM
adjustable profile family
Fri, Jul 20, 2012 at 9:08:25 AM
Creating wall elements with extensions
Mon, Feb 15, 2016 at 3:32:40 PM
Creating a family
Wed, Apr 15, 2015 at 8:43:02 AM
Creating a Family with Multiple Components
Mon, Dec 2, 2013 at 12:53:24 PM
Page generation time: 1.1086
