29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> Altering roofing structure in section views R2012
160 Posts No Rating |
I have a roof that meets with a parapet wall at 4deg. I want to detail a gutter up against the wall and would like to get rid of the lines of some of the roof elements, like the sheeting material, membrane layer, substrate etc.
Can I do this within the roofing edit assembly dialog or is it just as easy to draw over the top of the section, but then of course it will not show up in other views??
I appreciate any help.
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net |
Under the view tab / edit cut profile. You can read about this tool in yor help.
Thanks a lot Hub works a treat very intuitive, did not even need to go to help.
Cheers Dermot
www.dmbd.net |
Altering Revit Structure Wood Beam Families |
Mon, May 14, 2012 at 2:10:01 PM
Fatal errors in r2012 |
Sat, Jun 4, 2011 at 3:56:47 PM
Section X-Ref Parameters - Altering |
Tue, Jan 28, 2014 at 8:33:13 AM
Roofing Material Look alike |
Wed, Nov 21, 2012 at 5:35:57 PM
Roofing bay windows |
Wed, Mar 23, 2005 at 12:28:29 PM
