26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Curtain Panel - Divided Path
4 Posts No Rating |
I have a curtain panel that was built with divided path. The panel works perfectly, but the problem is that when I am on my building elevation (on the project file) all the path division points are visible and I cannot seem to find a way to turn them off. I attached 2 images for reference. Does anybody know how to control the visibility of the path division once the Curtain Panel family is loaded into the Project file? Thank you!
4 Posts No Rating |
Forgot to mention that I am using Revit 2013
VG > Mass > Nodes
VG > Mass > Nodes works, but in certain conditions. When mass visibility is set to "Show mass by view settings", Mass category is on, and Nodes off. Different settings might keep on showing the points of the divided path.
Edited on: Thu, Jul 19, 2012 at 1:41:51 PM
Planta1 Revit Online Consulting | info@planta1.com |
Parametric Curtain wall panel in divided surface |
Sun, Jan 31, 2010 at 8:08:54 AM
How to delete some in-place mass divided surface triangular curtain panel? |
Sun, Jun 9, 2013 at 1:50:48 PM
Curtain Panel Unexpectedly Mirrored in Project |
Fri, Feb 26, 2016 at 1:22:33 PM
Curtain system panel problem |
Tue, Jul 10, 2007 at 10:08:07 AM
curtain panel offset |
Mon, Sep 1, 2014 at 4:30:14 PM
