29 Users Online (27 Members):
Forums >> Community >> Newbies >> printing sheet sets - only the sheets
I'm printing my sheet set using the "Selected views/sheets" option under Print Range. I have deselected all of my the views and checked all of my sheets. However, all of the plan views are printing as well as the sheets. Surely I'm missing some setting? Anyone know where it is?
You're sure you've deselected all of your views? Sounds like some are still mixed in. Are you sure these plan views are not not sheets without titleblocks, by any chance?
Check over your sheet list and make sure there aren't any sheets in there that you don't wish to print.
I always start my selection set by checking "uncheck all", then I uncheck views and pick the sheets I want.
I am unchecking "Views", then unchecking all and individually selecting the sheets. The problem only seems to occur when ALL of the sheets are checked. So, if I were to only check 3/4 of the sheets taht's all I would get. But, when Iprint the entire set I also get the plan views that were created via levels, i.e. not duplicate views.
Remember .... Revit has a memory. If you don't first pick "uncheck all", then you are at risk.
Even if "Views" is unchecked? Ok, I'll give it a try. Thanks.
PRINT RANGE SETS BY PARAMETERS |
Wed, Feb 23, 2011 at 12:56:06 PM
Titleblocks |
Tue, Aug 2, 2005 at 5:36:17 PM
Revision clouds - off on one sheet but not on other sheets - is this possible? |
Fri, Mar 16, 2012 at 9:13:39 PM
Revit 2016 - Multiple Drawing Sets in Sheet Index |
Fri, Jan 12, 2018 at 10:38:33 AM
Printing Lineweights Correctly in Half Size Sets |
Tue, Jul 15, 2008 at 4:58:21 PM
