15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Shading Brickwork
Hi,
I have a wall with a darker brick soldier course running along it.
To show this in the elevations (in wireframe) I would like to give the solder course a darker shade.
I can't seem to do this, as the soldier course has a vertical line pattern to show the bricks, and so I cannot add a solid fill too.
See the attached image, I've achieved what I need by drawing a filled region with a solid pattern with opacity, but I really want to avoid waisting time drawing loads of filled regions.
Is there any simpler way of doing this?
Cheers.
Why are you showing an elevation in wireframe? If I were doing it, I would do an elevation with "Consistent Colors" as my visual style. Then just make your brick colors appropriate to whatever you desire.
The example I attached shows that just doing a shaded view doesn't help in elevations which is why you want consistent colors. I also used a light gray and dark gray for the brick but this certainly applies to any color.
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture |
I did think of doing that, but I found changing the materials in that way changes how the brick looks in all views. Ideally I want 3D views to show with colours correct.
Is it possible to do what you suggest only for the elevations - some sort of override?
unfortunately not that I can think of.... feel like I might be forgetting something though.
Shaded brickwork in elevation |
Mon, Jun 25, 2012 at 8:03:58 AM
Show brickwork only |
Tue, Aug 31, 2010 at 6:10:29 AM
Shading Toolbar |
Tue, Jun 22, 2004 at 9:54:36 PM
TOO DARK Shading with Edges Revit 2009 |
Mon, Aug 25, 2008 at 6:57:19 PM
11
shading with edges problem |
Wed, Nov 17, 2010 at 6:49:49 AM
