22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> TIFF image not displaying
When I insert a TIFF image in 2013 into a sheet view I get a white box. I've tried moving it to the foreground and brigning it to the front. I've checked the the raster images visibility in visibility graphics and it is turned on. If I insert a JPG file it displays as expected. Any ideas on why my TIFF files don't work would be appreciated.
Did you try converting your TIFF to a JPEG to see if it works with that same image?
Yes. A JPG of the same TIFF file works. So I have a work around it's just annoying and I'm wondering if its a bug or something I don't have set right.
Why would you use a tiff in the first place? The image size is not healthy to import in any case.
If you're counting on Tiff transparency to work, I do not believe it will.
One of my users received it and didn't know or ask how to convert it.
2 Posts No Rating |
HI there
You can just add a tiff processing program which supports to solve all kinds of tiff issues.
That would be more convenient.Hope to help you.
Masking a tiff. |
Wed, Jan 14, 2009 at 5:54:34 PM
Importing a TIFF file |
Fri, Mar 12, 2010 at 9:32:40 PM
windows in elevation and 3d not displaying correctly |
Thu, Oct 6, 2016 at 9:15:31 AM
Creating Topo using an image |
Mon, Feb 21, 2011 at 2:18:32 PM
Captured Rendering done at 200dpi, but saved/exported tiff is at 96 dpi ??? |
Tue, Aug 11, 2009 at 1:43:40 AM
