Forums >> Revit Building >> Technical Support >> Adding skylights and slopes to a roof
Wed, Jul 11, 2012 at 10:24:54 AM | Adding skylights and slopes to a roof
fastjohnnyz
 I am trying to determine what is the best way to add skylights and roof slopes. I basically have a rectangular bldg and a flat roof w/ multiple roof drains. Should I create a flat roof by footprint and then insert my skylights? Then edit my roof and modify my sub elements so that I can change the elevation points and have the slopes going to the drains?
Wed, Jul 11, 2012 at 11:01:13 AM | Adding skylights and slopes to a roof
The first question is, "DO I NEED TO MODEL THE ROOF SLOPES?".  Just because you can doesn't mean you should.  In most cases on low slope roofs, we add detail lines only on the roof plan for ridges, valleys and crickets.  This doesn't model right in sections so there we use edit cut profile to fix the insulation & roofing.
If you do decide to model it, the way you suggested is what we do.  But this is a pain when you need to edit the roof.
Wed, Jul 11, 2012 at 11:15:17 AM | Adding skylights and slopes to a roof
fastjohnnyz
Thx for the good info WW.
Wed, Jul 11, 2012 at 6:00:32 PM | Adding skylights and slopes to a roof
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
If you would like, you can model your roof flat, edit the roof type's structure, and check the check box to the right of the framing/insulation layer which says "variable."
Now, if you "modify interior points" on this roof, you can add elevation points and ridge lines, and the roof will have complicated and accurate slopes/crickets on top but stay flat on bottom.
Edited on: Wed, Jul 11, 2012 at 6:03:06 PM
Thu, Jul 12, 2012 at 8:33:07 AM | Adding skylights and slopes to a roof
fastjohnnyz
Thx ego. Worked like a charm
Skylight with slopes in 2 directions
Fri, Jun 7, 2019 at 10:54:49 AM
revit roof slopes
Tue, May 6, 2014 at 10:19:05 AM
Wall/Roof Attachment Phasing Issue
Mon, Sep 1, 2008 at 1:19:29 AM
Material adding to slope glazing
Mon, Jan 13, 2014 at 9:04:28 PM
window schedule - skylights
Wed, Jun 7, 2006 at 10:00:02 AM
Page generation time: 1.4546
