8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> Custum Area Type
7 Posts No Rating |
I have a building that has a very specific area schedule, about 12 categories. I need to know how to create custom area types. Anyone know how to do this. I can't organize by name because the names need to vary...
-Joe
You will need to start using shared parameters which you then associate with areas.
Our firm for example uses one I created called JMA_area_type (JMA is our firms initials)
You will want to consult the Revit help file and read it before diving into using shared parameters. The decisons you make on shared parameters today will be with you for a very long time so it is best to fully understand them before taking the plunge.
HTH
Tom
7 Posts No Rating |
Can you give a little bit more detail as to how you created your custom area types. Do I create a completely new Shared Parameter or can I edit the one that's already there... In addition how do I associate the new Area Type so that it creates a new correspond shade/color value.
I really appreciate the response.
Thanks,
-Joe
Creating custum glass doors in curtain walls |
Tue, Mar 27, 2012 at 5:00:29 AM
Adding an area color type |
Mon, Nov 3, 2014 at 7:05:20 PM
Area Plan - Occupancy type Revit Architecture 9.0 |
Mon, May 4, 2009 at 2:48:54 PM
Area Plans |
Wed, Nov 1, 2006 at 10:03:12 AM
Area Type - failed attempts to add |
Wed, Sep 2, 2009 at 7:31:34 AM
