Forums >> Revit Building >> Technical Support >> Project base point/ Survey Point
Tue, Jul 10, 2012 at 12:50:16 PM | Project base point/ Survey Point
DevonK
4 Stars: 5 Votes
In revit 2012, how do you work around survey coordinates larger than 30.000? Any information would be helpful. Thanks
Tue, Jul 10, 2012 at 12:53:37 PM | Project base point/ Survey Point
DevonK
4 Stars: 5 Votes
30,000 that would be
Tue, Jul 10, 2012 at 1:00:06 PM | Project base point/ Survey Point
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
What you are saying is that your surveyor is providing you with coordinate points outside the 30000 limit, which may be the limit for Revit. I would ask the surveyor to move the project to a different coodinate set. I personally have not had this happen to me however I have read it somewhere on this site before. Check the info below that might give you some simple advice.
Tue, Jul 10, 2012 at 1:20:11 PM | Project base point/ Survey Point
DevonK
4 Stars: 5 Votes
Yes, I can get it to work with truncated coordinates. Then we need to be able to get it back to the original coordinates in
AutoCAD. Is there any way to do this as we export it. Thanks for the reply.
Fri, Nov 9, 2012 at 3:14:31 PM | Project base point/ Survey Point
anastas
I have this same problem. Civil origin is outside the 20 mile limit. The file comes in, but it causes problems for rendering linework from these linked files. I thought I had a solution with the AutoCAD base point, but Revit does not recognize the autocad base point.
We are trying to void having to move the civil and landscape files every time we get backgrounds.
Sat, Nov 10, 2012 at 5:14:45 AM | Project base point/ Survey Point
4 Stars: 205 Votes
In AUTOCAD open that file and create a WBLOCK, select what you need, now you have a "clean" file to use in Revit
Mon, Nov 12, 2012 at 11:05:39 AM | Project base point/ Survey Point
anastas
Yeah, that is the obvious solution, but I was hoping for an internal Revit solution so I don't have to do the relocation every time since we sometimes receive backgrounds as many as twice a week.
So the official answer is THERE IS NO SOLUTION. I am considering this a bug in Revit that has not yet been resolved.
Mon, Nov 12, 2012 at 12:21:51 PM | Project base point/ Survey Point
Publish your coordinates back to your CAD files and have your consultants use that.  From your HELP:
Publish Coordinates
When you publish shared coordinates from a host Revit Architecture project to a linked DWG, this changes the linked DWG. The origin of the host Revit Architecture project’s shared coordinate system becomes the origin of a new User Coordinate System (UCS) in the DWG file. The Y axis of the new UCS corresponds to the host project's True North. You can name the UCS when you publish coordinates. It is not recommended that you change this name after publishing coordinates.
To publish coordinates:
  1. Click Manage tabProject Location panelCoordinates drop-down (Publish Coordinates).
  2. Place the cursor on a linked model instance and click.
  3. Select a named position from the linked model, and click OK.
    See Defining Named Positions.
The linked model file now has the same shared coordinates as the host model file.
Mon, Nov 12, 2012 at 4:13:25 PM | Project base point/ Survey Point
anastas
Unfortunately Civil needs to have their CAD based on an exact X and Y coordinate for construction coordination. They cannot move their 0,0 which is at the heart of the problem. In most cases we could simply used Shared Coordinates, however the shared coordinate would be more than 20 miles from the site which is what is causing the rendering problems in Revit.
To get to the solution what I really need is for Revit to consider Autocad Base points before the 0,0 origin. That's why I said it's a Revit bug. this is something AutoCAD had setup and was working fine between AutoCAD files, but needs to migrate over to Revit now.
Tue, Nov 13, 2012 at 9:22:00 AM | Project base point/ Survey Point
Please reread the HELP instructions.  0,0 is NOT moved!
Tue, Nov 13, 2012 at 3:35:36 PM | Project base point/ Survey Point
#11
anastas
Yes, I'm aware of that. Thanks though.
Level that reads both Project Base Point and Project Survey Point
Tue, Jun 9, 2015 at 9:39:37 AM
Project Base Point
Thu, Jul 2, 2009 at 6:24:59 AM
Display both Project Base Point and Survey Point on Elevation Datum.
Fri, Aug 29, 2014 at 5:57:41 PM
Spot Elevation/ Level with both "project base point" and "survey point" 2017
Mon, Nov 27, 2017 at 5:33:42 PM
Topography Elevation from Project Base and Survey Point is Incorrect
Thu, Jan 29, 2015 at 10:32:24 PM
Page generation time: 0.9262
