Forums >> Community >> Newbies >> Permanently isolate object in Revit?
Tue, Jul 10, 2012 at 7:06:28 AM | Permanently isolate object in Revit?
broigutt
Is there any way to permanently isolate objects in Revit?
I have many objects in my project that i am making fabrication drawings for and i am having problems of always having to go through the sheets to fix my drawings
I have tried to use assemblies but it is only helping to a certain extent.
Would be great if there was a option like temporary isolate that only was permanently isolate.
Tue, Jul 10, 2012 at 7:09:12 AM | Permanently isolate object in Revit?
Isolate?  Are you using the correct term?
Would groups be your answer?
Tue, Jul 10, 2012 at 7:30:12 AM | Permanently isolate object in Revit?
broigutt
I think i am using the correct term yeah
I would like if there was an option to isolate objects and it would work permanently not only temporarly like the "tempoaray isolate object" does
Tue, Jul 10, 2012 at 7:32:41 AM | Permanently isolate object in Revit?
You mean only show that object in a view then.
There would be a couple of ways to do this.  The best would be to put this object in a workset by itself, then create a view and turn off all worksets but this one.
Tue, Jul 10, 2012 at 7:42:47 AM | Permanently isolate object in Revit?
broigutt
Yes that is what i mean.
I dont have much experience working with worksets but i guess i have to check it out
Usually everything is in a single workset in my projects so i dont have to think about it.
How is normal working method for worksets?
Thanks for great responses as always.
Tue, Jul 10, 2012 at 8:14:03 AM | Permanently isolate object in Revit?
broigutt
How do i turn off workset in single view?
Tue, Jul 10, 2012 at 8:14:50 AM | Permanently isolate object in Revit?
VG settings in that view.
Wishing for improvements to Isolate by Category.
Wed, Sep 7, 2011 at 3:47:40 AM
Isolate Command
Thu, Feb 26, 2009 at 4:07:25 PM
HOW TO ISOLATE A FLOOR PLAN FOR RENDERING ?
Mon, Aug 3, 2009 at 7:05:07 AM
Capabilities to isolate phases
Tue, Nov 28, 2006 at 5:43:02 AM
Isolate dimensions
Mon, Jun 1, 2009 at 8:05:43 PM
Page generation time: 2.2660
