14 Users Online (12 Members):
Forums >> Revit Structure >> Technical Support >> Help Needed: Unsolved Linked file Question
15 Posts No Rating |
I have a topography revit file linked to the main host file : Revit 2012
Below here are a few screen shots in the file enclosed, that show my settings in different windows.
This file was prepared by another architect and I am suppose to finish it. I am boggled :-( as to how to get the topo lines to be visible in the site plan when they are visible in all other plans and sections.
I really appreciate your response and am hoping to get it solved in this forum.
Thankx
PS
Your term "linked contour Revit file" is a little confusing. You mean linked model site - correct - the contours are a result of the model, not drawn. Saying "contours" indicates to mean you may be describing an imported 2D file.
It is really easy to see if you have more than one topo.... I believe you do because some people don't understand graded regions. Simply cross the corner of the topo and see how many you have. If you have multiples, delet one and see what you have left. Then you can decide if you need to switch which one you may want to delete if any.
You do know that your view cut is below your topo? That is why the topo cross hatch shows from there on up.
Not sure what the problem is, but a trick I use when views get all messed up is to simply create a new plan view from scratch, copy aligned the annotations to new view and delete the old.
http://www.turbosquid.com/Search/Artists/Revitaoist |
Linked Revit Topography file displayed in hidden lines in 3d view main bld file |
Sat, Jul 7, 2012 at 3:38:16 PM
Linked File Section Question |
Mon, May 5, 2014 at 10:24:09 AM
HELP NEEDED - DIMENSIONS TO BEAMS LINKED IN FROM MULTIPLE REVIT FILES |
Mon, Jul 30, 2012 at 8:30:29 AM
Revit Linked File Question: UNABLE to unhide linked contour in Site plan window |
Tue, Jul 10, 2012 at 3:42:09 PM
Linked File, how can I dimension it? |
Sun, Dec 19, 2010 at 8:08:50 PM
