Forums >> Community >> The Studio >> Exterior House Details
Thu, Jan 5, 2006 at 10:18:31 AM | Exterior House Details
chssleepers
3.5 Stars: 13 Votes
I would like to add some exterior details to enhance the elevations of houses that we are designing. These details include window casings, corner boards, pilaster (flat columns on the wall), water tables, belt lines etc. Banging my head against the wall too long to figure it out on my own. Is there an easy way???
Thu, Jan 5, 2006 at 1:25:58 PM | RE: Exterior House Details
Rythmick
5 Stars: 2 Votes
Use the search tool on this forum or others to look for families and tips that may suite your needs . You need to learn the abilities of the sweep and create tools along with the family editor. Do a tutorial on wall sweeps.
Fri, Jan 6, 2006 at 1:47:24 AM | RE: Exterior House Details
jobcaptain
jobcaptain Avatar
1 Stars: 2 Votes
When you have a moment, consider checking out my blog and blog archive (at the bottom), I have a few posts dedicated to residential design that came from working with Revit clients over the last 4 years. Tech / Business Blog URL www.taylor-tech.com/danielhughes Residential Design: Revit 2D Sketch Tools Define 3D Curb Appeal for Homeowners http://taylor-tech.com/blogs/getEntryById/52/entry.html There is a PDF and DWF file you can download that I use in my training classes and a Revit Gallery link that you can access Revit Residential, commercial, instutional, etc projects...I think there's more than 20 projects. Residential Designers-Builders Sell Their Projects Using Revit Design Options and Whole House Modeling http://taylor-tech.com/blogs/getEntryById/50/entry.html Cheers!
LinkedIn Profile:
  • http://www.linkedin.com/in/danielhughes1/
I author Bradley BIM Blog: http://bradleybim.com
Fri, Feb 29, 2008 at 9:08:16 AM | Exterior House Details
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
none of those links work?  Do you have updated links on that IMAGINiT site?
I can't find them.  We're a Residential Based company and it would be very helpful to get those tutorials and guidelines you're talking about.  I would appreciate any insight.  Thanks,Lorne
Denver, CO
Revit Architecture
Fri, Feb 29, 2008 at 10:35:46 AM | lorne17
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting lorne17 from 2008-02-29 09:08:16
ditto
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Feb 29, 2008 at 6:56:04 PM | Exterior House Details
JTG76
I hope this might save you a few minutes of headache:
In our office, we always have the best intentions of going somewhere online and getting a detail to use in our models, but most of what I have found never quite works out. I have saved more time (and learned more about modeling) by creating some in-place components. If it is a once-in-a-lifetime sort of component that our office will never use again, I will create the component within the model itself. Using reference planes and a little savvy, we can usually jazz up our models well enough to a make a nice set of drawings that tells the story. If it is a component that we like and commonly specify on projects, it only makes sense to create it in the family editor so that we can have it to add to our office's collection of goodies. It's easy to get carried away and draw too much, so I try to be selective as to what gets modeled, and what doesn't. Overall, my point is, I have had much more luck using components I have made verses using components I have found online. Just my two cents. Best of luck.
 -JTG76
Fri, Feb 29, 2008 at 9:40:07 PM | Exterior House Details
coreed
coreed Avatar
4 Stars: 16 Votes
i always review any free reference material to get a gauge what being produced and and to what detail. No matter what, it seems i always seem to learn something. i never turn down an opportunity when offerred. The Revit scale seems to be a constantly variable one.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Mar 3, 2008 at 11:10:44 AM | Exterior House Details
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
I was merely wanting those links to work, because I'd like a GOOD tutorial to help me get some details created.  That's all.  I wasn't looking for Detail components.  Our details are pretty unique and I understand we'll be making our own.  But I would like a tutorial to help get me started in the detail process.  Does that make sense?
Thanks,
Lorne
Denver, CO
Revit Architecture
Victorian House
Wed, Sep 11, 2013 at 12:25:36 PM
Exterior Floor Question
Fri, Jun 5, 2009 at 2:17:52 PM
creating brick and vinyl siding on an exterior wall.
Tue, Feb 5, 2008 at 3:08:52 PM
Problem when applying a footing to wall
Thu, Aug 23, 2012 at 1:18:20 PM
How do i add wood siding in the exterior wall? Need major help!
Tue, May 15, 2018 at 9:57:18 AM
Page generation time: 0.1891
