Forums >> Revit Building >> Technical Support >> Profiles
Sat, Jul 7, 2012 at 4:43:22 PM | Profiles
rgaaia
R11 I am having trouble attaching a profile i created to a sweep. i built the profile as a regular one and gave it the generic category. i created a sweep  and tried to attach it and i get the error that i cannot create.
Any ideas.
Sat, Jul 7, 2012 at 6:20:19 PM | Profiles
You have a path that the profile can not follow without doubling back on itself.  Profiles work best when the path is on the inside of the path and the profile is completely outside that.  << This is an oversimplification but it may help you understand.
Do some experimenting with simple profiles located at different points relative to a path that turns a right angle.
Reorder profiles button?!
Thu, Sep 11, 2014 at 4:38:37 PM
loading profiles
Sat, Feb 18, 2012 at 3:43:54 AM
roofs and profiles
Tue, Feb 22, 2011 at 12:29:13 PM
Save Profiles
Fri, Dec 17, 2010 at 1:13:23 PM
Stair Railing Profiles
Mon, Mar 23, 2009 at 12:03:20 PM
Page generation time: 1.3603
