Forums >> Revit Building >> Technical Support >> How to get wall to run to underside sofit/underside of slab
Fri, Jul 6, 2012 at 11:22:39 AM | How to get wall to run to underside sofit/underside of slab
kepners
How to get wall to run to underside sofit/underside of slab rather than running through the structure above or having to calculate individual bits of wall to run around bulkheads etc?
Fri, Jul 6, 2012 at 11:54:22 AM | How to get wall to run to underside sofit/underside of slab
You can have walls connect to the underside of floors and roofs automatically trimming to that shape.
Click on the wall and pick which end you want to attach to... attach top/base.
Edited on: Fri, Jul 6, 2012 at 11:54:40 AM
Creating drop panels to the underside of a sloped floor slab
Fri, Feb 12, 2016 at 9:41:01 AM
stepped underside of straight run monolithic stair
Tue, Dec 17, 2013 at 7:39:25 AM
underside of stair
Tue, Jun 24, 2014 at 9:17:50 AM
Centerline elevation of pipe below underside of floor above
Mon, Dec 22, 2014 at 8:11:21 AM
Wall projection to underside of curved roof
Thu, Feb 2, 2012 at 5:19:28 PM
Page generation time: 2.1989
