Forums >> Revit Building >> Technical Support >> Address Lable
Thu, Jan 5, 2006 at 10:17:04 AM | Address Lable
quiller
quiller Avatar
2.5 Stars: 3 Votes
How can I modify the address lable in the lable dialog box when creating a sheet to read client address. I need one for project address and one for client address.
Thu, Jan 5, 2006 at 12:15:40 PM | RE: Address Lable
TomDorner
4.5 Stars: 25 Votes
The "project address" is hard coded in Revit and cannot be changed. You can however add new fields using shared parameters so you could add a "client address" box. For simplicity sake though it might just be easier to accept the default "project address" and enter your information in this type of way into the project address text box: --------------------------------- Project Address: 123 Street Name Anywhere US, 12345 Client Address: 456 XYZ Street Somewhere, US 45678 --------------------------------- You would need to modify your titleblock to have a enough area for the project address to grow in length.
Thu, Jan 5, 2006 at 4:06:29 PM | RE: Address Lable
quiller
quiller Avatar
2.5 Stars: 3 Votes
i figured as much. I did however manage to create a shared parameter and brought it into the sheet template and into the project. But for some reason when I load it in the project all I get is a question mark. If you load it into a project and click on the sheet you'll see the question mark. Also I can't seem to find a way to set it up so I can enter the address info. I've attached the sheet template. Thanks......
Wed, Feb 22, 2006 at 11:30:07 AM | RE: Address Lablel
Mactn113
Has anyone found a solution to this problem? I am experiencing the same thing. (Question marks where my shared parameters should be) Is there a way to add parameters to the System Family: Project information? I found the info in another post- http://www.revitcity.com/forums.php?action=viewthread&thread_id=3056 Post edited on 2006-02-22 13:35:01
Align Text and/or Lable
Mon, Aug 7, 2017 at 5:27:00 AM
Editing Multiple Text Contents
Tue, Sep 30, 2008 at 10:08:06 AM
How do I fix the RL lable in elevation?
Mon, Mar 14, 2005 at 9:59:13 PM
Keynote Text Wrapping
Fri, Sep 24, 2010 at 1:27:55 AM
adding a lable to keynotes
Fri, Jun 8, 2007 at 10:46:36 AM
Page generation time: 0.0292
