15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Insert POINT at specific coordinate
90 Posts No Rating |
I got the coordinares of 4 points that define the limites/area of a property.
How can I creates points and move them to specific coordinates on Revit?
http://screencast.com/t/jpvJZGlQ
Note: I know I can do it on AutoCAD and then import but lets forget about that
Do you wanna SKYPE Revit? Its quicker  |
27 Posts No Rating |
hi did you find a solution for this? everyone just suggests exporting it to autocad but i don't think that is a very good solutions. i was surprised that you couldnt just add a spot coordinate and type in your northing and easting and it move your object/annotation..........
anyone got any suggestions??
cheers
I would do this using the survey point and the project location point. Once the survey point is located, the project point can be moved to each coordiante and a reference point can be placed.
I would rather describe the property using the property line tool. Enter all the bearings and distance in the chart and your done.
Edited on: Fri, May 16, 2014 at 7:48:08 AM
I have a similar problem...
I am using Revit 2015. I have a topographical inserted and i have my building arranged and it is all coordinated, great.
However the contractor has now given me 3 sets of coordinates for, electric, gas and water and would like them indicating on the next revision.
How do i locate those coordinates?
Again i know i can do this in CAD, but how do i do it in Revit.
Am guessing this is a glaring omission so as it can be brought in as a 'feature' in a later edition so we upgrade...?
Will the reset the Survey point affect consultant links? |
Fri, Oct 22, 2010 at 10:26:13 AM
Locating a Coordinate... |
Thu, Apr 21, 2016 at 10:45:21 AM
Insert North Point Annotation Symbol |
Thu, Aug 4, 2011 at 1:04:42 AM
Survey Point and UTM coordinates |
Mon, Jun 20, 2016 at 3:50:02 PM
Allow 3 point Definition for Reference Planes |
Mon, Mar 28, 2005 at 8:53:52 PM
