11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Eleminate Column Split in Schedules
105 Posts No Rating |
I had a long drawing index schedule that was too long to fit on the sheet so I "split" it so it showed two columns. Now I want to re-merge those columns in to a single column again. I can drag the length until all the sheets show in one column but the other adjacent column heading does not disappear. How do I get this all back into one column?
Grab the other column and slam it against the bottom of the first column. They will merge.
I was trying to link it to the bottom and that does not work, but if you put the heading close together then it grabs it a merges. I found that out by trying to slam it in quickly and overshooting the bottom. I hate it when I am befuddled by the simplest of things ... thanks for the help.
Titles on split Schedules |
Thu, Jun 13, 2013 at 1:48:24 PM
Can column grids be split? |
Wed, Aug 3, 2011 at 3:07:49 PM
Concrete Columns shown split in Column Schedule |
Wed, Aug 19, 2020 at 8:16:11 AM
Graphical Column Schedules problem.... |
Wed, Sep 9, 2015 at 12:41:56 PM
Base Plates & Graphical Column Schedules |
Mon, Feb 22, 2010 at 11:51:01 AM
