Forums >> Revit Building >> Technical Support >> Importing Revit Drawings
Thu, Jan 5, 2006 at 10:05:17 AM | Importing Revit Drawings
Nathan
4.5 Stars: 3 Votes
When trying to load a saved revit drawing into an open revit drawing I encountered a problem. The drawing seemed to go across but became invisible. I know this as when I tried to import the same drawing again I got the following message: At least one instance of this link already exists. It could be invisible because the link is unloaded. Continuing will create a new instance for this link and reload it. Can anyone explain what happened and how to successfully import the drawing Thanks
Wed, Nov 22, 2006 at 4:17:40 PM | Importing Revit Drawings
JesseGLY
Check your visibility settings under the Revit Links tab and make sure you have them checked.
importing autocad drawings
Fri, Jan 15, 2010 at 10:27:49 AM
Importing ACAD Drawings - Experiences?
Fri, Aug 6, 2004 at 8:54:57 PM
Importing from AutoCAD - distant origins
Mon, Mar 17, 2008 at 6:00:27 AM
Importing .dwgs into Revit
Mon, Feb 9, 2004 at 5:13:11 PM
Imported Drawings Visibility Issues
Mon, Oct 8, 2007 at 4:08:24 PM
Page generation time: 1.3126
