Forums >> Revit Building >> Technical Support >> RAC 2012 Modify Tab on Ribbon
Thu, Jul 5, 2012 at 9:17:54 AM | RAC 2012 Modify Tab on Ribbon
ianOK
So the ribbon has been giving me fits recently. Anytime I select an "in-place component" and modify it, the "Modify" tab on the ribbon never changes back to say "Modify", but it keeps the name "Picked Path > Sweep > Sweep > Pick Path". I am completely done editing the component and have exited all the way out of the edit command. Even when I select another element to edit (a wall for example) it still has the "Picked Path....." on the tab.
Any ideas why it does this or how to fix it?
Thu, Jul 5, 2012 at 9:49:44 AM | RAC 2012 Modify Tab on Ribbon
4 Stars: 205 Votes
Do you have the latest update to Revit 2012 installed?
Check here: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=16841348
Thu, Jul 5, 2012 at 10:27:41 AM | RAC 2012 Modify Tab on Ribbon
ianOK
Communication center says I have no updates available, so I believe it is up to date. Is there somewhere else I should check?
How do I modify building pad in Revit Structure 2012?
Fri, Aug 19, 2011 at 4:50:24 PM
revit 2012-contextual ribbon tab not show
Thu, May 30, 2013 at 2:45:26 AM
How to modify an area scheme - RAC 2012
Thu, Nov 29, 2012 at 2:51:01 PM
Can't Get Modify Schedules/Quantities tab to turn off - Revit 2014
Thu, Mar 30, 2017 at 1:15:02 PM
No Add-ins tab in my ribbon
Wed, Oct 17, 2012 at 9:27:01 AM
Page generation time: 0.2771
