Forums >> Revit Structure >> Technical Support >> overwrite label in callout tag
Tue, Jul 3, 2012 at 11:21:03 AM | overwrite label in callout tag
Gitaroo
hi, anyone know how to overwrite the sheet number and detail number in a callout tag? I tried to make a new one, but it doesn't look like it has a category parameter that let me do manual overwrite. Im using Revit 2012
Tue, Jul 3, 2012 at 11:38:19 AM | overwrite label in callout tag
This is the great part of Revit.  The tags are smart, why would we want to make them dumb like CAD?
If you want to make a callout that references an already created view, then do that and the tag will be right.
Tue, Jul 3, 2012 at 11:45:29 AM | overwrite label in callout tag
Gitaroo
the thing is, my company is doing a pilot project with revit and we have all the standard details in CAD they we have setup and completed already. I have to put call out tags in my revit plan that reference back to them. And no we are not linking or inserting those cad detail back into revit because they are already done. So all tags are now referenced to nothing. I want to add detail numbers and sheet number manually. I know the procedure to do it properly, but wonder if there is a quick way to just do a manual overwrite on the tags directly.
Edited on: Tue, Jul 3, 2012 at 12:25:34 PM
Tue, Jul 3, 2012 at 12:09:57 PM | overwrite label in callout tag
For now - create a sheet with the same number as the cad sheet and place simple drafting views (nothing but name) on the sheet and reference these.
I think the better solution is to import the cad details seperately into drafting views and place those on your sheets.  Then everything is in Revit.  Easier to work on, print, store - everything.
Tue, Jul 3, 2012 at 12:30:50 PM | overwrite label in callout tag
Gitaroo
Yes, thats what I am doing now but taking too long and kind of running out of time, same thing with wall section and section details. And my company put SIM. or MIR out side of the call out bubble for similar and mirrord details. I drop them to the same sheet to get the sheet number, but they cant be using the same detail number which has become another problem. An manual overwrite function can basically fix all of these problem instanstly.
Label in Callout Floor Plan Tag
Tue, Dec 29, 2009 at 3:13:13 PM
Detail callout tag... for 2010
Wed, Nov 11, 2009 at 11:58:51 AM
Callout tags
Thu, May 1, 2008 at 11:39:20 PM
12
Wall's tag in callout view
Mon, Nov 11, 2013 at 7:28:44 AM
Revit 2022 - Tag or Label always horizontal
Thu, Jun 16, 2022 at 1:01:08 PM
Page generation time: 6.1885
