Forums >> Revit Building >> Technical Support >> mssing surface pattern
Tue, Jul 3, 2012 at 9:49:06 AM | mssing surface pattern
Wader
I have recently created a custom stone pattern, but when viewed in elevation and 3D all I see is a solid color.....and no pattern.  I can manipulate the color in the material editor.....under the surface pattern section, but I don't see any option to have no color fill.  I can't seem to get rid of the color to allow just the pattern to be visible.
As usual any advise is appreciated
Tue, Jul 3, 2012 at 9:56:07 AM | mssing surface pattern
Your PDF was not helpful.  Was it the Green area?
Did you assign this pattern to a material?
Remember, a pattern does not render - only materials with an assigned jpg image will render.  The pattern is only good for non-rendered views.  So if you also want this to render, you will also have to set the image in the material.
Tue, Jul 3, 2012 at 10:09:51 AM | mssing surface pattern
Wader
The green area represents the area of the missing pattern.  The image is not a rendering just a shaded view. The problem is still there in hidden line view.
Tue, Jul 3, 2012 at 10:15:24 AM | mssing surface pattern
I'll ask again....
... And dit you assign this material to the wall...?
and I will also ask this - this is a model view - the hatch has to be a model hatch.
Tue, Jul 3, 2012 at 10:48:35 AM | mssing surface pattern
Wader
I assigned the pattern to the material and its renders as stone properly...its just that the pattern seems to be overridden by a color fill
Tue, Jul 3, 2012 at 10:49:25 AM | mssing surface pattern
Wader
Its a model pattern as well
Surface pattern
Mon, Sep 10, 2007 at 11:18:01 AM
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:33 AM
19
SURFACE PATTERN LINE WEIGHT
Fri, Mar 28, 2014 at 2:30:00 PM
voronoi surface pattern
Fri, Jun 24, 2011 at 2:14:03 PM
Surface pattern problem
Tue, May 18, 2010 at 9:15:56 AM
Page generation time: 0.2721
