19 Users Online (17 Members):
Forums >> Revit Building >> Tips & Tricks >> how to override values of level grids?
5 Posts No Rating |
like the one you can do in dimensions, you can text-override the dimension
how do i do this in level grids? the function seems missing. thanks
What do you mean with "override values of level grids" ?
You can't override a level, if you set a level at 100'-0" thats what it is at.
9 Posts No Rating |
It can be done using shared parameters and creating a new level head annotation family and type. We use it occationally when we need the elevation to read as "VARIES" rather than a specific value.
~SwiftImage |
12 Posts No Rating |
Or you could move the enitre building/project by altering the coordinates and thereby the elevation height of each level.
It depends on what you re trying to do. Faking a level height is NOT a good idea or good practice. As SwiftImage stated, if you are trying to get a "VARIES" type not on there then you can use an annotation symbol which is not associated with your levels and will be view specific.
Aligning grids the same in each level? |
Fri, Sep 23, 2005 at 11:13:39 PM
new user - copying grids to other levels |
Mon, Dec 6, 2010 at 3:06:35 PM
Elevation Level Override |
Thu, Apr 5, 2018 at 1:22:35 PM
Changing level height values while keeping building in place? [ 1 2 ] |
Mon, Apr 13, 2015 at 1:47:48 AM
18
Applying changes in grid to all views |
Wed, Dec 26, 2012 at 9:22:57 AM
