Forums >> Revit Building >> Technical Support >> Spot Levels
Mon, Jul 2, 2012 at 5:25:26 PM | Spot Levels
vhugomg
Hi,
I have a view on my project with a lot of floors that I am detailing with a lot of spot levels. It is a big master view.
This view has a problem with the spot levels. I cannot put any spot level on the inside surface of the floors but I can put them on the perimeter or in the interior edges, slabs, etc.
Why is this happening?, I really need to be able to put spot levels on the face of the floor and not only on the perimeter and this has to be an error, because it happens on some views and not all the time.
I tried a lot of things to solve it but im running out of ideas.
I will be grateful with anyone who can be able to help me with this one.
Thanks.
Tue, Jul 3, 2012 at 7:17:43 AM | Spot Levels
This does not happen to me except on ramps which don't spot elevate at all.
Try creating a new plan from the view tab - (Don't just copy the view.)
Tue, Jul 3, 2012 at 7:53:44 AM | Spot Levels
4 Stars: 205 Votes
We are talking about "Spot Elevations" right???
(This one...)
Edited on: Tue, Jul 3, 2012 at 7:55:59 AM
Tue, Jul 3, 2012 at 9:23:18 AM | Spot Levels
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
You can find the spot elevation of a ramp at any point, if you first place the spot elevation on a floor, and then move the
spot elevation to the ramp. Is it a bug? Probably, but that's how it works.
Edited on: Tue, Jul 3, 2012 at 10:10:45 AM
Planta1 Revit Online Consulting | info@planta1.com
Tue, Jul 3, 2012 at 9:52:17 AM | Spot Levels
Alf - good tip
.... I don't know that I ever tried this but I may have. ...Glad you posted.
Tue, Jul 3, 2012 at 12:11:51 PM | Spot Levels
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
No problem. This "trick" is similar to a trick I learned from Jeff Hanson about annotating the slope of a ramp. It works in the same way.
Wed, Jul 4, 2012 at 3:45:20 AM | Spot Levels
4 Stars: 205 Votes
Very, very good Alf....
Another way and you don't need a "floor":
Goto a 3D view and orient the view to "Top" or to a "Plan view",  place the "Spot Elevations" like you want in that ramp, now Copy to clipboard, goto the plan view and PASTE (To current view, same place...).
About the "Slope" of a ramp a simple Copy / Paste (Ctrl-C / Ctrl-V) solve the issue...
Hope this Help...
Edited on: Wed, Jul 4, 2012 at 4:24:54 AM
Wed, Jul 4, 2012 at 1:04:45 PM | Spot Levels
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
Well, there you go, yet another way. Thanks!
Additional note for the developers: wouldn't it be nice to simply put the annotations on top of the ramps and have the information immediately, without any workarounds?
Edited on: Wed, Jul 4, 2012 at 1:05:17 PM
Edited on: Wed, Jul 4, 2012 at 4:45:39 PM
Thu, Jul 5, 2012 at 4:08:29 AM | Spot Levels
4 Stars: 205 Votes
"Additional note for the developers: wouldn't it be nice to simply put the annotations on top of the ramps and have the information immediately, without any workarounds?" - DITTO!!!
Fri, Jul 6, 2012 at 1:32:18 PM | Spot Levels
vhugomg
Thak you for your responses. I have an error on a view and it wont let me put levels on some floors, but it is difficult to explain and I think is view related only.
I will make a new view and problem solved.
Regards
Fri, Jul 6, 2012 at 3:23:24 PM | Spot Levels
sllana
5 Stars: 2 Votes
well, maybe anyone of you can help me with a similar problem: when trying to put a spot elevation in a sectioned stair, it doesnt seems to see the steps nor the rest of the stair. Any trick? What i have done is to put it in the base of an object tha resides on that level. Dont like it.
Sat, Jul 7, 2012 at 4:19:06 AM | Spot Levels
4 Stars: 205 Votes
Place one SE in the base of the stair (first tread) then copy that and place wherever you want OR change the view range in that view to see the whole stair, place the SE then change again the view range.
Edited on: Sat, Jul 7, 2012 at 4:19:24 AM
Mon, Jul 9, 2012 at 9:52:35 AM | Spot Levels
#13
sllana
5 Stars: 2 Votes
thanks a lot typhoon, for the solution to that case, but what i was asking was a different one: in a section view. See the image please, and tell me if there is a way to do that. thank you.
Mon, Jul 9, 2012 at 10:45:34 AM | Spot Levels
#14
4 Stars: 205 Votes
Place a little ref. plane in that section view then place the SE and select th RP.
Mon, Jul 9, 2012 at 11:36:36 AM | Spot Levels
#15
vhugomg
When spot levels just don't work in my section view, I just draw a little horizontal detail line and I put the spot level just in the line. If you do this you can then select the detail line and the spot level will turn blue and you can type the level that works for your stair.
Winking
Spot levels on external floor family
Fri, Aug 17, 2007 at 2:44:13 AM
Spot elevations text on angle
Thu, Oct 18, 2012 at 9:08:09 AM
Spot Elevation vs. Level elevation
Tue, Aug 19, 2025 at 1:06:15 AM
Adding 100' to Spot Elevation
Tue, Jan 31, 2012 at 10:36:28 AM
Setting a manual height for Spot Elevations in plan
Wed, May 27, 2015 at 8:03:11 AM
Page generation time: 0.2702
