Forums >> Revit Structure >> Technical Support >> How to Create a Filter to Identify Specific Top of Wall Elevations
Sun, Jul 1, 2012 at 3:43:32 PM | How to Create a Filter to Identify Specific Top of Wall Elevations
DNP0
Hello RevitCity Forum.
I am looking for assistance in defining the parameters required to create a filter to identify and color code wall elements that have specific top of wall spot elevations in plan view.
For example, the attached concrete grade beam section is constructed with an 18” wide tall wall element (below) and a 10” wide X 0’-4” tall wall element (curb) joined on top.  The plan view illustrates the curb (green) and the balance of the grade beam (below) in purple.
The intent is to create a plan view that will use a filter to identify and color code the wall elements that are at elevation 5’-2” (similar to the attached color coded plan view).  Please note that there are several grade beam configurations therefore the wall thicknesses that may be at elevation 5’-2” can be of any thickness and height.
The colors on the plan view have been applied via graphic overrides based on manually selecting the walls that have a top elevation = 5’-2”.  This method works, but has the obvious issue as it is a static analysis and relies on manual-visual identification.  If the walls change in elevation then the surface pattern identifications will not change unless manually modified.
The question.
What is the process to create a filter that will programmatically identify only the wall elements (of any thickness) that have a specific given top elevation (5’-2” for this example)?
Also, it seems the parameter formula “Height” = “Area” / “Length” is not 100% accurate; especially for walls that do not have constant cross-section as illustrated in the elevation view.
Searching this and other forums has not yet provided the specific answer and my apologies if there is a solution posted to this or a similar question.  Thanks in advance.
DNP
Edited on: Mon, Jul 2, 2012 at 6:59:51 PM
Fri, Feb 6, 2015 at 10:44:36 AM | How to Create a Filter to Identify Specific Top of Wall Elevations
ashevilleARCH
Did you ever find a way to accomplish this?
create a filter for floor surface patterns below
Mon, Dec 3, 2018 at 6:51:01 AM
the correct way to filter out elevations
Thu, Apr 4, 2013 at 4:23:01 PM
Filter views on a sheet by revision
Tue, Jun 2, 2015 at 4:06:28 PM
Walls that will not Filter
Tue, Jun 12, 2007 at 1:53:35 PM
Override Phase Filter for Specific View only
Fri, Nov 4, 2016 at 9:45:40 AM
Page generation time: 2.2510
