Forums >> Revit Building >> Technical Support >> All annotations plotting light.
Thu, Jun 28, 2012 at 3:24:13 PM | All annotations plotting light.
cboersen
I have a problem with all my annotation (sections, dimensions, text) plotting light.  It appears dark on the screen and no setting I can find says it is half tone.  What else could cause those things to plot light?
Thu, Jun 28, 2012 at 3:49:14 PM | All annotations plotting light.
If you are plotting a sheet and have the view active, the view will be printed screened.
Fri, Jun 29, 2012 at 5:58:15 AM | All annotations plotting light.
cboersen
True,  but that would screen everything and that is not the case.  It is also not just one sheet, it is the whole set.
Fri, Jun 29, 2012 at 6:44:53 AM | All annotations plotting light.
If you have plotted before and not had this problem then:
  • Is this a new system?
  • Is this an upgrade in Revit?
  • Is this a different plotter?
What happens when you plot to PDF?
Cannot get ALL annotations to show up in a single plan view
Mon, May 21, 2012 at 10:43:12 AM
Plotting
Fri, Apr 28, 2006 at 8:31:02 PM
plotting
Mon, Jul 7, 2008 at 3:02:05 PM
plotting to a plotting service plotter with a prn file
Wed, Jun 4, 2008 at 1:14:56 PM
Electrical symbols plotting to light.
Tue, Jun 4, 2013 at 9:34:32 AM
Page generation time: 0.4520
