Forums >> Revit Building >> Technical Support >> Revit 2013 Rendering and Materials
Thu, Jun 28, 2012 at 12:38:45 PM | Revit 2013 Rendering and Materials
bajoyce
bajoyce Avatar
3.5 Stars: 3 Votes
I am using Revit 2013 and I am have a rough time getting my machine to render completely. If I render with any setting over "medium" (and even medium experiences the same issue), the render percentage will reach 100%, but the image does not complete on the screen. If I send the view to the cloud, it will render completely. I am also noticing  that when I am changing materials, it is taking a very long time just to get the material directory to appear as well as to actually "apply" the material change to the object. I am running 16GB of RAM, an NVIDIA Qaudro 2000 1GB graphic card. Has anyone else run into similar issues? Is this a Revit "glitch", or is there an issue with my desktop (which is only 1 month old)?
Fri, Jun 29, 2012 at 5:01:13 AM | Revit 2013 Rendering and Materials
4 Stars: 205 Votes
I never had any problem like this and I only have 12GB of RAM and when I render is always in High or Best to the "final product"...
You are running in a 64 bits OS correct? What's the file size? Specifications of your machine?
Fri, Jun 29, 2012 at 8:41:37 AM | Revit 2013 Rendering and Materials
coreed
coreed Avatar
4 Stars: 16 Votes
just curious, what type of system did you buy?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Jun 29, 2012 at 2:29:50 PM | Revit 2013 Rendering and Materials
bajoyce
bajoyce Avatar
3.5 Stars: 3 Votes
The desktop is a BOXX 4050 XTREME. 64 bit, Intel i7, 16 GB RAM, 24GB SSD, and 500 GB HD. I am thinking it may be an issue with the harddrive. Total Revit project file size is only 100 MB. This is the second BOXX system I have bought and my other system only had 12GB RAM and lower performing components and I never had a rendering issue. Got this one because my sytem was given to an newbie.
Fri, Jun 29, 2012 at 3:57:54 PM | Revit 2013 Rendering and Materials
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi beyonce!!!, how are you?, I use RAC 2013 on my pc (16 RAM, 1GB gc & 500 GB HD) and no problems at all, and it has 2 months old...
Mon, Jul 2, 2012 at 10:49:23 AM | Revit 2013 Rendering and Materials
DESIGN4BUILDING
DESIGN4BUILDING Avatar
3.5 Stars: 3 Votes
what about service packs, and Nvidia has updates for the revit issues, maybe try that ?
Sun, Nov 25, 2012 at 1:11:08 AM | Revit 2013 Rendering and Materials
Audiophyle
I had a very similar issue with Revit2012 a while back
http://www.revitcity.com/forums.php?action=viewthread&thread_id=25895
Turned out to be due to the processor being overclocked, and although running completely stable the CPU just needed some extra juice.  If your setup is overclocked, you need to go into the BIOS (or contact retailer) and turn the voltage up a bit.
Fixed my problem, and Revit2013 doesnt have any issues with my machine now either.
REVIT 2013 Materials Library Video Tutorial
Tue, May 28, 2013 at 5:12:56 AM
13
Revit materials missing at rendering [ 1 2 ]
Tue, Jun 14, 2011 at 11:24:21 PM
22
Revit Custom Materials Rendering Objects invisble
Mon, Mar 14, 2011 at 10:42:55 AM
13
REVIT 2013 materials library
Fri, Mar 15, 2013 at 3:15:31 PM
11
Revit 2013 GPU Rendering using - Quadro 2000, 4000, & 6000
Wed, Apr 10, 2013 at 10:17:50 AM
Page generation time: 1.9063
