15 Users Online (13 Members):
Forums >> Community >> Newbies >> How do I copy 3D vies from one project to another?
Greetings,
I have built a client's' existing' house with some 3D views. I have saved a copy to be my 'proposed' house to which I will make the client's modifications. I want to be able to have both 'existing' and 'proposed' views which are exactly the same (like for like) for a client presentation. The views set up in the 'existing' project are still present in the 'proposed' but I have now created new views in the 'proposed' project that i want to put into the 'existing' project. I suppose I could try to recreate these manually by eye but I would prefer a quicker alternative if one exists.
I am using Revit Arch 2011 any help would be greatly appreciated.
Cheers.
Chunkeymonkey.
Edited on: Thu, Jun 28, 2012 at 9:45:01 AM
Was the 3D view made using the camera? This post may help you
http://revitclinic.typepad.com/my_weblog/2010/03/copy-a-camera-walkthrough-between-project-files.html
Fantastic, that worked a treat, thanks very much.
3 Posts No Rating |
Any idea if this can be done somehow for default 3D views?
There is not a way to copy the actual 3D view from one project to another.
3 Posts No Rating |
Actually I found out that there is a way.
Open the same plan view in both projects.
Right click on the 1st project's project browser the 3D view you want to copy -> Select Show camera -> Press Ctrl + C (Copy) being on the 1st project plan view .> Go to the 2nd Project same plan view -> Go to Paste Alligned to view.
That 's it. Tested, it works.
Copy Legend to New Project? |
Wed, Feb 20, 2013 at 3:37:10 PM
13
Copy/paste section to new project |
Thu, Sep 10, 2015 at 10:21:13 AM
Can you copy project peices into a new project? |
Wed, May 4, 2011 at 1:13:17 PM
How to copy over entire project |
Wed, Nov 7, 2007 at 10:38:31 AM
Collaborate - Copy command changes type |
Fri, Nov 6, 2015 at 1:35:14 PM
