Forums >> Revit Building >> Technical Support >> dwg disappears after exploding
Wed, Jun 27, 2012 at 4:24:17 PM | dwg disappears after exploding
jarosa
jarosa Avatar
4 Stars: 5 Votes
I'm am trying to explode a block in a temporary file to create a detail element. I followed WB's instructions in a previous post but when I explode the file in Revit it just disappears.
Wed, Jun 27, 2012 at 4:33:57 PM | dwg disappears after exploding
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Do you get any warnings when it disappears?  Personally I don't like to explode DWG's because there are to many things that can go wrong like getting unwanted layers in Revit so I typically just Import CAD then use the import as a background and redraw the detail in the Revit lines I want.
Wed, Jun 27, 2012 at 5:34:54 PM | dwg disappears after exploding
jarosa
jarosa Avatar
4 Stars: 5 Votes
No warnings. It's a temporary file and I want to use the cad lines for a detail and copy paste into a clean file. ??
Wed, Jun 27, 2012 at 5:43:34 PM | dwg disappears after exploding
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
I did this just a few minutes ago.
You said a block.  A cad block might behave differently?  I am not sure.  Best would be to explode that in ACAD first so that revit has simple cad lines to explode, itself.  I know what you mean about vanishing after explosion, but I've strictly run into that with 3D imports.
Thu, Jun 28, 2012 at 4:47:26 PM | dwg disappears after exploding
jarosa
jarosa Avatar
4 Stars: 5 Votes
EXPLODING IMPORTED FILES
Tue, Oct 17, 2006 at 2:01:20 AM
Importing DWG with clipped blocks
Mon, Sep 17, 2012 at 12:00:44 PM
cad link disappears
Thu, Mar 14, 2013 at 2:44:21 PM
Reference DWG disappearing when zoomed
Mon, Jan 2, 2012 at 2:28:43 PM
Pipe disappears after connecting to unit
Sun, Aug 23, 2009 at 2:51:50 PM
Page generation time: 0.4350
