14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Family Modeling
If it best to build a custom window as a family or a seperate project? Becuase i would like to be able to use it multiple times in seperate projects.
FAMILY!
Ahh--as a separate family. Not to be confused with a separate project.
If that's what you meant. Go to options (big purple R)-->new-->family-->window. You'll have to select it from the long list of available family templates. Now, you model it just as if you were making an in-place family. Except in this case you can reuse it in any other project.
Family would be the way to go.
Ok cool thanks! So what i need to do is open up a new family file> then i select window > when i do that it gives me a wall with a an opening already in it. So do i delete all of that? or do i build the custom window using that wall and opening already given? Why cant i just get rid of all that in the file and just start building a window from scratch
"So do i delete all of that? or do i build the custom window using that wall and opening already given? Why cant i just get rid of all that in the file and just start building a window from scratch"
NO! do not delete the preset family items. They will help you in creating your window family. There are some preset parameters that you will use to get started on your window.
You should read through the Families Guide
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=13080413&linkID=9243097
Modeling a family outside of Revit |
Mon, Dec 19, 2005 at 11:39:34 PM
Revit modeling services provided [ 1 2 ] |
Sat, Jun 27, 2009 at 3:13:55 AM
16
3D Family modeling questions-Arrrggghhhh! |
Mon, Jan 23, 2012 at 10:43:12 AM
13
Family Modeling |
Mon, Sep 8, 2008 at 11:49:44 AM
Modeling-family |
Tue, Aug 10, 2010 at 7:48:53 AM
