15 Users Online (13 Members):
Forums >> Community >> Newbies >> How do you set Rectangle as default drafting instrument?
17 Posts No Rating |
How do you set Rectangle as default instrument when drawing walls for example?
You will have to pick the rectangle when you draw your walls, drawing by LINE is Revits default.
Cheers. Can you set it as a UI command?
4 Posts No Rating |
Hey,
You can only have line tool as the default, but you could always set it as a shortcut command.
I would think that is the fastest way, althought you would need to set all differant shortcuts for walls, detail lines, ETC.
Hope that helps
Cheers
Default setting for detail title on inserted drafting views |
Thu, Mar 21, 2013 at 9:41:45 AM
Room number rectangle size |
Thu, Sep 5, 2013 at 1:03:25 PM
repeating detail that can be stretched |
Mon, Feb 18, 2019 at 2:39:19 PM
Set default 3D view |
Tue, Feb 18, 2014 at 11:31:43 AM
Setting Default Wall Constraints |
Fri, Jan 5, 2007 at 2:45:05 PM
