Forums >> Community >> Newbies >> Workplane "viewer" what is it??
Tue, Jun 26, 2012 at 12:33:18 PM | Workplane "viewer" what is it??
kepners
Workplane "viewer" what is it?? The reason i asked is that i just opened it up (being nosey) and saw a ton of walls and curtainwalling that i have drawn and deleted. However it was all recorded on there. Why?
Tue, Jun 26, 2012 at 12:40:33 PM | Workplane "viewer" what is it??
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
The Workplane Viewer is a great tool. Especially in family creation and editing. It should not show objects you 'deleted' ?? It may show objects yuou have hidden.
Tue, Jun 26, 2012 at 1:01:24 PM | Workplane "viewer" what is it??
TKennedy
4 Stars: 8 Votes
How are you using it? It seems like it should be an awesome tool, but I just haven't found anything to do with it. I'm sure I'm just missing something.
Tue, Jun 26, 2012 at 1:33:52 PM | dgcad
kepners
Quoting dgcad from 2012-06-26 12:40:33
Honestly i havent drawn anything hidden! i have literally just hours in to this. And i have found walls that i drew in error anf deleted. However, to note i was using "e" shortcut to delete/erase and this is not the proper Delete command- so this could be my issue. I will confirm in the coming days.
However, what is it for again. could you explain it again. I really didnt understand. I do understand that Families are like Blocks from autocad.
Workplanes issue: Unable to dissassociate objects and masses from workplane
Tue, Dec 2, 2008 at 3:09:56 PM
changing the "family" and "type" names
Mon, Apr 2, 2007 at 5:33:49 PM
How to bend my workplane to fit curtain surface... ?
Tue, Feb 24, 2009 at 8:05:40 AM
Can't figure out how to insert Recessed Can lighting into ceiling plan
Mon, Aug 16, 2010 at 12:50:05 PM
Model Lines in Ceiling Plan
Mon, Dec 10, 2007 at 10:47:59 AM
Page generation time: 1.0222
