Forums >> Community >> Newbies >> Deleting an element within 3D environment doesn't delete the element from the 2D
Tue, Jun 26, 2012 at 12:16:02 PM | Deleting an element within 3D environment doesn't delete the element from the 2D
kepners
Deleting an element within 3D environment doesn't delete the element from the 2D environment why? I am finding as a newbie i am making tones of mistakes and pressing "E" the "space bar" to delete say a wall in my 3D model space. Why doesnt that very same wall get removed/ deleted in the 2D space. Do i have to have both windows Tabb'ed side by side for this to work?
Tue, Jun 26, 2012 at 12:23:41 PM | Deleting an element within 3D environment doesn't delete the element from the 2D
You are absolutly incorrect.  When a model element is deleted anywhere, it is deleted everywhere - period!
2D Elements are view specific.  Not sure what you are doing or what your shortcuts may be.  I usually just select the object and hit the delete key.
Tue, Jun 26, 2012 at 12:29:23 PM | Deleting an element within 3D environment doesn't delete the element from the 2D
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
do you maybe have a 2D AutoCAD plan link in that was used to trace over top? maybe that is what your seeing.
Tue, Jun 26, 2012 at 12:30:55 PM | Deleting an element within 3D environment doesn't delete the element from the 2D
kepners
aHH! Your are indeed correct! I was using the Delete for just that space! cheers. I have just changed my UI so delete is now E also.
Tue, Jun 26, 2012 at 12:46:07 PM | Deleting an element within 3D environment doesn't delete the element from the 2D
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
2D elements, linework, annotations, tags and dimensions are 'view specific'. You would need to delete in all views even though you can copy and paste them from view to view. They are not associated with their originator.
3D Elements will be deleted in all views. Thngs like walls, floors, stairs, roofs, pipes, ducts, furniture, toilets, casework, railings. . . . etc.
If you do not want to see a 3d element in a specific view you can hide the element or hide the entire category.
Keep a positive attitude. . . . you'll get there.
Tue, Jun 26, 2012 at 1:35:59 PM | dgcad
kepners
Quoting dgcad from 2012-06-26 12:46:07
View Specific! thats brilliant. thank you.
Can't delete infilling element without deleting its insert or host.
Tue, Sep 8, 2009 at 3:29:45 PM
can't delete sweep
Wed, Jun 25, 2008 at 3:25:04 PM
Assigning a scope box to a section leads forces me to the delete the section.
Mon, Jan 11, 2016 at 10:10:53 PM
Family Element ID's
Thu, Jul 2, 2009 at 11:19:17 AM
switching element type to curtain element error
Wed, Nov 16, 2011 at 1:37:03 PM
Page generation time: 1.9591
