20 Users Online (18 Members):
Forums >> Community >> Newbies >> Newbee here. Revit 2013 align issue... cant get walls to join
17 Posts No Rating |
Hi Everyone. My Name is kepners. Not only am i a newbee here and I am also new to revit.
OK, so! I have the book and following a youtube video on how to use align. I draw out a rough rectangle and align each side to my grid reference. Simple... NOPE! three of the four sides align to the grid the final side/corner then pings up an error message along the lines of "Highlighted walls overlap. One of them may be ignored when Revit finds room boundaries. Use Cut Geometry to embed one wall within the other." So i have tried rather than align it i drag the highlighted blue wall to the grid line it then separates at the corner in question.
Now, i have been messing around for a few days on this and i am making no head way at all. I have also found that I cant even align Curtain walling... to grid lines.
I really need help on this. any ideas why this is happening. I have attched the two DWF's of the problem.
Align tool... select the grid line then select the wall nothing more than that, in your image just use the "trim" tool to "close" thiose walls.
There is something wrong within my model. As its pinging error everytime i draw a wall... and splitting the walls. I have attached my model.
I have tried drawing walls at only 3000mm height not even to sofit (underside of slab) aswell as alighing from Center of wall and not face. It still pings away!
I would like to thank everyone who replied on here. I have solved it. I was incorrectly Deleting items and there being "hidden" in revit and whilst using Workplane i deleted everything i had drawn and its working perfectly. THanks again.
Keps
Revit 2015 join wall to underside of floor and ceiling issue |
Wed, Mar 2, 2016 at 2:59:03 PM
walls overlap but dont join. |
Sat, Jul 30, 2016 at 5:13:58 PM
90degree wall join |
Sun, Aug 20, 2006 at 9:08:54 PM
Revit Structure 2013 |
Tue, Feb 26, 2013 at 2:39:11 PM
Join walls command for a group. Issue |
Sun, May 13, 2018 at 11:06:02 PM
