Forums >> Revit Building >> Technical Support >> Watts vs. Kilo-watts in Revit Arch 2012
Mon, Jun 25, 2012 at 8:42:08 AM | Watts vs. Kilo-watts in Revit Arch 2012
HWurtele
HWurtele Avatar
I'm trying to format a chart for a server room that calculates the total amount of servers in kW instead of Watts.  When I try and change the project units to kW in under settings/project units, there is no drop down of kilo-watts.  Is there a way I add this parameter into the project or is this something that would have to be done in the MEP version of Revit?
Thanks.
Mon, Jun 25, 2012 at 9:14:20 AM | Watts vs. Kilo-watts in Revit Arch 2012
TKennedy
4 Stars: 8 Votes
I've been creating a calculated value that divides Watts by 1000, then hiding the Watts column. Seems to be working ok.
Mon, Jun 25, 2012 at 10:05:10 AM | Watts vs. Kilo-watts in Revit Arch 2012
HWurtele
HWurtele Avatar
Thanks for the reply, but when I try to set a calc. value that divides by 1000 i get an error message that reads "improper used of boolean expressions.  The formula I'm entering is Wattage/1000
Mon, Jun 25, 2012 at 10:28:44 AM | Watts vs. Kilo-watts in Revit Arch 2012
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Try removing the Wattage units by multiplying the Wattage by -1 first. Crying* Wattage -1).
The smiley face shown above above is supposed to be an open bracket.
Edited on: Mon, Jun 25, 2012 at 10:29:52 AM
Mon, Jun 25, 2012 at 10:33:59 AM | Watts vs. Kilo-watts in Revit Arch 2012
HWurtele
HWurtele Avatar
thanks. but i'm getting the same message
'Inconsistent units" error in parameter formula; length vs integer
Fri, Dec 13, 2013 at 10:37:04 PM
lighting fixtures
Mon, Mar 19, 2012 at 10:10:42 PM
SETTINGS FOR LIGHTING...
Fri, May 16, 2008 at 7:09:23 AM
plzzzzzz help with the whole syestem configuration...........everything.........
Wed, Sep 3, 2008 at 12:30:53 PM
Interior Rendering is very Dark
Tue, Apr 30, 2013 at 2:30:55 PM
Page generation time: 2.1669
