Forums >> Revit Structure >> Technical Support >> Problem when transferring reinforcement between Robot and Revit (Extention)
Sun, Jun 24, 2012 at 6:42:33 PM | Problem when transferring reinforcement between Robot and Revit (Extention)
yasserkishawi
yasserkishawi Avatar
Hi All, I have modelled a frame in revit and used the revit extention (Reinforcement Design), in Robot when I use the set of bars (within ACI 318-08 metric) (for example rebar of diameter 13, 19, 36) the extention works very well and the reinforcement is tranfered to Revit element, However in Robot when I modify the reinforcment database (using the job preferences) and add bars with 12mm, 14mm, 20mm, etc. the new rebars doesn't tranfered to Revit element, How can I add whatever rebars I need and transfere the reinfrocement successfully? Kindlu help?
revit structure to robot millennium
Fri, Dec 26, 2008 at 4:08:18 AM
CONCRETE WALL REINFORCEMENT VOLUME & AND STRUCTURAL TRAINING COURSES
Wed, Sep 19, 2007 at 12:01:03 PM
Unknown Run-Time Error (Revit to Robot)
Mon, Dec 27, 2021 at 2:24:48 PM
Rebar/Reinforcement Scheduling Area Reinforcement
Wed, Mar 9, 2011 at 4:59:36 PM
Unable to start robot analysis structure (HELP NEEDED)
Tue, Apr 29, 2014 at 10:11:09 AM
Page generation time: 1.5628
