Forums >> Revit Building >> Technical Support >> Getting rid of shadows in Revit rendering?
Thu, Jun 21, 2012 at 9:31:51 AM | Getting rid of shadows in Revit rendering?
4birdman
I'm an MEP guy so this is stumping me. I am trying to help someone out by doing a rendering of some rooms.
Is there any way to render so that there are no shadows?
I have it set up so the walls are transparent and all my colors set, but when I do render the sun is casting shadows. Is there any way to do a rendering without shadows and have it full of light still?
Thu, Jun 21, 2012 at 9:45:18 AM | Getting rid of shadows in Revit rendering?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
In Render setting you can control the Sun and Shadows.
Thu, Jun 21, 2012 at 10:08:26 AM | Getting rid of shadows in Revit rendering?
4birdman
I still can't get it to not cast shadows. I'm not sure what I'm doing wrong.
Thu, Jun 21, 2012 at 10:22:22 AM | Getting rid of shadows in Revit rendering?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I don't believe that you will be able to completely turn them off but look up "soft shadows" in your help menu
Thu, Jun 21, 2012 at 4:38:47 PM | Getting rid of shadows in Revit rendering?
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
I am genuinely curious -- If you are not interested in shadows, then why are you doing a rendering?
If you want the render materials only, then I would suggest the "Realistic" view style.  With or without edges.
Mon, Jun 25, 2012 at 3:46:09 AM | Getting rid of shadows in Revit rendering?
Warchitect
4 Stars: 5 Votes
try turning off sun and shadows in the 3d view before you go to Render window. otherwise, the post above is the answer.
Sun, Dec 3, 2017 at 2:06:46 AM | Getting rid of shadows in Revit rendering?
aravindb
YES!! you have to adjust sun settings.before rendering ,in sun settings-lighting-set azimuth and altitude as 90
Revit shadows in rendering
Thu, Jan 14, 2010 at 12:14:48 PM
Rendering problem with soft shadows on Revit Arch 2010
Wed, Jan 20, 2010 at 5:58:33 PM
Moving shadows in animations
Thu, May 5, 2011 at 5:42:26 PM
rendering no shadows
Fri, Aug 31, 2007 at 2:21:06 AM
Elevation rendering - roof shadows
Wed, Jun 16, 2004 at 1:13:00 PM
Page generation time: 2.5124
