Forums >> Revit Building >> Technical Support >> goining from 8.1 to 8.0
Wed, Jan 4, 2006 at 7:30:03 AM | goining from 8.1 to 8.0
hammer87
hammer87 Avatar
3 Stars: 4 Votes
i ve downlodaded the 8.1 version from the revit site, go it installed on my home computer so ican work on it at home at school. one problem though at school we have 8.0 so any work that i do at home wont open at school. any one have any ideas on how to get around this?
Wed, Jan 4, 2006 at 11:31:30 AM | RE: goining from 8.1 to 8.0
TomDorner
4.5 Stars: 25 Votes
Use 8.1 at school is the only option. Revit cannot save back to previous versions (no database can). Tom
Wed, Jan 4, 2006 at 12:18:41 PM | RE: goining from 8.1 to 8.0
hammer87
hammer87 Avatar
3 Stars: 4 Votes
so could i upgrade the 8.0 version at school to 8.1 or would i have to uninstall it and install 8.1?
Wed, Jan 4, 2006 at 1:09:02 PM | RE: goining from 8.1 to 8.0
TomDorner
4.5 Stars: 25 Votes
You can have both versions intalled at the same time. Check with your insturctor or network administrator though to determine what you have a license for. If you install 8.1 and don't have a license for it, you can active a 30 day trial, but then after the 30 days you are going to be in the same boat you are in now. Tom
Wed, Jan 4, 2006 at 5:52:00 PM | RE: goining from 8.1 to 8.0
hammer87
hammer87 Avatar
3 Stars: 4 Votes
could i use the same license as i did from 8.0?
Wed, Jan 4, 2006 at 6:41:37 PM | RE: goining from 8.1 to 8.0
TomDorner
4.5 Stars: 25 Votes
I believe the point release require a new activation. Since we are on subscription I don't pay too much attention to the licensing issue. I'm not sure how Autodesk handles the educational license which is why you need to check with your network administrator. Tom
Thu, Jan 5, 2006 at 7:33:53 AM | RE: goining from 8.1 to 8.0
hammer87
hammer87 Avatar
3 Stars: 4 Votes
ok thanks, what i was thinking though is since i have a thumb drive (512MB) that i could send the program to there and use it from the thumb drive. would that work? i also have one thats a 256MB. 0
Thu, Jan 5, 2006 at 12:02:59 PM | RE: goining from 8.1 to 8.0
TomDorner
4.5 Stars: 25 Votes
Sorry...won't work. Revit needs to be installed under Windows and will not run as a USB application. It would be nice if it could though as that is the way a lot of applications are heading. In the not too distant future your sofware and files will reside on a USB drive you can take anywhere. Meantime check this out: http://www.usbapps.com/archives/cat_applications.html Tom
Thu, Jan 5, 2006 at 12:22:14 PM | RE: goining from 8.1 to 8.0
hammer87
hammer87 Avatar
3 Stars: 4 Votes
well, actuall what i was thinking was sending the program itself from the program files, to zip drive then to the thumb drive.
Page generation time: 0.6060
