Forums >> Revit Building >> Technical Support >> Civil Construction Drawings in Revit Architecture 2013
Wed, Jun 20, 2012 at 8:05:41 AM | Civil Construction Drawings in Revit Architecture 2013
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
We are starting a project in Revit 2013 and I was curious if anyone out there is using Revit for their civil drawings?  We are trying to decide if it would be best to just continue to draw the civil in AutoCAD (architecture) like we normally do or if we should try to do it in Revit.  All I have read about was people saying that Revit isn't really good for civil work.  We don't need any renderings so 3D views are not needed so we could essentially just creat the site with detail lines and no model elements but is that worth switching over from CAD?
Wed, Jun 20, 2012 at 8:22:05 AM | Civil Construction Drawings in Revit Architecture 2013
It sounds to me like Civil 3D AutoCAD is still the best solution.
http://blogs.microdesk.com/index.php/2011/05/civil-3d-and-revit-how-can-we-play-well-together/
Wed, Jun 20, 2012 at 1:11:55 PM | Civil Construction Drawings in Revit Architecture 2013
4 Stars: 205 Votes
Great software, I work with it everyday...
http://labs.autodesk.com/utilities/civil3d_bridge/
http://bimontherocks.typepad.com/
http://fromthegroundup.typepad.com/from_the_ground_up/2012/03/httpyoutube7qlmm1z9lwe.html
Wed, Jun 20, 2012 at 1:22:26 PM | Civil Construction Drawings in Revit Architecture 2013
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Unfortunately we do not have Civil 3D so we have to either use AutoCAD or Revit
Wed, Jun 20, 2012 at 1:33:41 PM | Civil Construction Drawings in Revit Architecture 2013
In CAD, you are just doing 2D stuff - right?
I suggest, you allow your surveyor create the CAD topograpy/survey drawing that you use to create your 3D Revit site model and you do everything else in REVIT.  2D if you need to just ike you currently do.
Wed, Jun 20, 2012 at 1:46:19 PM | Civil Construction Drawings in Revit Architecture 2013
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Right.  That is exactly what I suggsted we do, Thanks!
Thu, Jun 21, 2012 at 1:13:09 PM | Civil Construction Drawings in Revit Architecture 2013
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
http://www.eaglepoint.com/products/siteworksforrevit/index.html
You might take a look at the above. I am using some techniques of which there are several to create streets roads, etc. and you can use MEP to create basic piping plans etc.
Sun, Jan 31, 2016 at 2:37:03 AM | Civil Construction Drawings in Revit Architecture 2013
kenneths
So you can have variety of possible working options, try the both in Revit and in AutoCadd.
http://eatmywords.com/services/names/
AIA Best Practices - Organizing Construction Documents
Thu, Mar 20, 2014 at 2:36:36 PM
Linking a civil 3D CAD file to Revit Architecture 2012
Thu, Jan 12, 2012 at 6:48:02 PM
Construction Drawings Samples?
Sun, Aug 28, 2005 at 6:00:54 PM
Revit for construction drawings
Mon, May 24, 2010 at 1:39:23 PM
Thu, Oct 20, 2005 at 8:21:56 AM
Page generation time: 4.0676
