Forums >> Revit Building >> Technical Support >> Linking models issue- coordinates
Tue, Jun 19, 2012 at 9:10:48 AM | Linking models issue- coordinates
davet
Hi Guys,
I have been assigned a task of showing how much rock is in our site prior to construction commencing. Taken from surveys a Revit model has been produced by a colleague. However when linking it in to the model it sits 2m too low.
Not having a great deal of experience with coordinates I presume the creator did not assign the same coordinates to the rock profile model. Can anything be done now the rock has been modelled up rather than starting from scratch?
Advice is appreciated.
Tue, Jun 19, 2012 at 10:28:13 AM | Linking models issue- coordinates
If you don't need real site elevations (numbers) anywhere, then you can create the site and just move it in section relative to your model.
Otherwise, you need to read you HELP on how to relocate your project.
Linking models with multiple sites
Wed, Dec 6, 2017 at 9:43:09 AM
linking models via origin to origin problem
Wed, Sep 30, 2015 at 10:20:09 AM
Shared coordinates and IFC link positioning
Sun, Oct 8, 2017 at 7:05:12 PM
Survey Point and UTM coordinates
Mon, Jun 20, 2016 at 3:50:02 PM
Shared Coordinates while linking Dwg into Rvt
Thu, Jun 5, 2014 at 12:06:32 PM
Page generation time: 0.9382
