Forums >> Revit Building >> Technical Support >> 3D Site Plan Coordination
Tue, Jun 19, 2012 at 9:03:17 AM | 3D Site Plan Coordination
davet
Hi Guys'
Could anyone assist me please. I have created a site plan in 3D for logistics for a project. This was done by linking in a Surveyed CAD plan and tracing it to get footprints etc. As the plan was for visual purposes i did not regard the Elevation of the model.
Now the model has been created I have been asked to show topography as it is on a slope and to allocate the correct elevation to it to link in proposed buildings.
Can this be done once the model had been created? If so is it straight forward? I do have the surveyed coordinates to use.
Your help would be appreciated.
Tue, Jun 19, 2012 at 2:57:19 PM | 3D Site Plan Coordination
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Does the cad plan have the contours with a Z coordinate?  If it does you can use the  "Create from Import" tool.
Thu, Jul 12, 2012 at 7:39:56 AM | 3D Site Plan Coordination
davet
It does have contours on, however when I go to create from inport my plan ends up looking like a mountain range.
Thu, Jul 12, 2012 at 7:55:07 AM | 3D Site Plan Coordination
If it looks like a mountain range then that is because the person who created this in CAD was sloppy.  Because CAD is not typically used in 3D, these drafters often add items that are not set in the Z direction.  I would tell them to fix it if they are your contract.  Otherwise, you should look at the CAD plan in 3D cad, identify the bad elements and either fix or delete them.
site plan disappears intermittently
Thu, Mar 16, 2017 at 9:21:12 PM
Problem with Reigion Hatching on Site Plan [ 1 2 ]
Tue, Feb 25, 2014 at 4:19:15 PM
26
help!!! deleted site plan!
Fri, Aug 7, 2015 at 9:23:10 PM
13
Advice on creating a site plan
Mon, Jul 12, 2010 at 5:04:03 PM
BIM coordination role
Tue, Apr 9, 2013 at 4:58:33 PM
Page generation time: 0.5053
