16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Revit 2013 Schedules
Is it possible to make a schedule that include all family's and system family's in the project
I have tried a multi-Category schedule, but can't make it include system family's
Your question is unclear.
Roofs, floors, walls are all system families and they will schedule. << Separately If you want a multicategory schedule then you need parameters that span multiple categories.
From your HELP:
Creating a Multi-Category Schedule
- Place several components into your project that have shared parameters.
- Click View tab
Create panel Schedules drop-down (Schedule/Quantities).
- In the New Schedule dialog, select <Multi-Category> from the Category list. Click OK.
- In the Fields tab of the Schedule Properties dialog, you notice that shared parameters are available as schedulable fields. Add the appropriate shared parameter to the scheduled fields list.
- Click the Filter tab in the Schedule Properties dialog and choose the shared project parameter you just added. Only components that have this parameter display in the schedule.
NoteIf you do not specify a filter parameter for the schedule, then all family categories in your project that can have a shared project parameter will display in the schedule. See Categories Allowing Shared Parameters.
- Format the rest of the schedule as desired. For more information, see Specifying Schedule Properties.
- When finished, click OK.
The schedule lists all components with the shared parameter.
TipYou can modify or add a shared parameter in the Fields tab of the Schedule Properties dialog. To modify a shared parameter, select it and click Edit under Scheduled fields. To add a new parameter, click Add Parameter. In both cases, the Parameter Properties dialog opens.
Using Schedules to Drive Families |
Fri, Nov 22, 2013 at 7:14:05 AM
Combining Room Schedules and Area Schedules into one Large Schedule |
Thu, Jan 3, 2013 at 10:57:33 AM
multiple schedules |
Tue, May 1, 2012 at 1:04:42 PM
Schedules for Information In Schedules HAHA |
Mon, Feb 13, 2012 at 12:08:12 PM
Schedules on multiple sheets |
Thu, Apr 27, 2006 at 11:01:59 PM
