23 Users Online (21 Members):
Forums >> Revit Systems >> Technical Support >> How to fixed error when uploading family to project rvt. file
6 Posts No Rating |
Hi,
Can anybody know how to fixed error of family type when uploading in project file.
The error message is - (Warning can be ignored) Extrussion is too thin ....
it might be the way of modeling the family but how can I check it?
Thanks
FMAR
Expand the error message and get an ID number. Then search for that ID.
6 Posts No Rating |
Hi WWHub,
I search for the id no. of the mention error but another messages occur - The following Elements IDs are invalid and won't be used: #....
Is there any other way to fixed this error.
Thanks
FMRA
This element must be within your family and is numbered when it comes in. You will not find it.
You need to look at this family and see what parameters are set when loaded. Some things look fine in the family but will never work in the project. This can be true for hosted objects because the host might be so different. That would be the first place to look. For instance if your project wall is only 4" thick and in your door family, the host is 8". In this example, change this host to 4" and see what happens.
Without knowing more about the family and use, I can't help much more.
Did you try to audit the file before opening?
Revit Template File from Project file .rvt to .rte |
Sun, Apr 28, 2013 at 1:35:39 AM
Help! How to save a template file as an rvt file? |
Wed, Aug 20, 2008 at 11:27:01 PM
Odd Family Behavior - Absorbing .RVT file info. |
Wed, May 19, 2010 at 3:30:56 PM
A fatal error loading family into project overwriting existing |
Mon, Jun 22, 2015 at 8:03:38 AM
Uploading a family to project |
Mon, Apr 3, 2006 at 10:10:22 PM
